Check engine light not on at a start
165,163 MILES • 6 CYL • TURBO • AUTOMATIC
EFISIWORLD
My check engine light will not up when I turn on the ignition but every other light does.
Jan 9, 2018 at 7:25 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Check the "meter" fuse in the junction block located behind left side of dash.
Jan 9, 2018 at 10:52 PM
EFISIWORLD
What should I do at the meta fuse box because all fuses are okay?
Jan 10, 2018 at 7:13 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It is a single fuse labeled "meter" in the junction block located behind left side of dash that you should check and make sure it is not blown and if you have a voltmeter or at least a twelve volt test light, make sure this single "meter" fuse has voltage on both sides of it.
Jan 10, 2018 at 10:04 PM
