Check engine light is on, runs rough when shifting gears
135,000 MILES • 3.6L • V6 • 4WD • MANUAL
MIKE WOOD2
94 Nissan pickup, check engine light is on and it seems to be running rough when accelerating and when shifting gears, especially when going from 4th to 5th gear. Runs smoother when at speed, but loses power when going uphill and runs rough again.
Changed plugs, plug cables, fuel and air filter. O2 sensor bad maybe? Vac problem? Not sure where to go next with this.
May 5, 2019 at 5:30 AM
  • 55,746 POSTS
It sounds like you have a vacuum leak or misfire, did you do cap and rotor? Also we should get the codes here is a guide to help walk you through the steps.
https://www.2carpros.com/articles/nissan-obd1-diagnostic-trouble-codes-and-retrieval-procedure-1984-to-1994
and
May 6, 2019 at 9:13 AM
