Check engine light came on in March reads torque converter but have no symptoms-still driving it. Recently started overheating but found out there was no coolant took the entire jug to fill it. I unhooked the battery so I could see if the coolant tripped the light but the light never went off. Could this be a blown fuse? I cannot get anyone to believe there are no torque converter symptoms because all they are seeing is the repair money. Transmission fluid has been checked and looks clean.
Dec 19, 2017 at 4:21 AM
