P0441 Evaporative Emission Control System Incorrect Purge Flow. Fastest way to test this is with a scan tool and a smoke machine. It could be many things. From a rusty filler neck to a bad purge control valve and about 10 others. Some you can visually inspect but most you need the abilities of a scan tool to open/close the various valves as you test them.
Aug 3, 2017 at 8:01 AM
