Getting a rough idle at times with black smoke coming from exhaust. Also i keep blowing an engine sensor fuse.
Jul 2, 2019 at 10:41 AM
SCGRANTURISMO
✓Experienced Mechanic
If your malfunction Indicator Lamp (MIL) or "check engine" lamp is illuminated you will need to pull the Direct Trouble Code(s)(DTC)(s) for us. Here is a link for you to go to if you are unfamiliar with how to do this:
Please pull the DTC(s) and get back to us with what is/they are. We will be able to provide you with specific guides to get the problem fixed.
Thanks,
Alex
2CarPros
Jul 2, 2019 at 9:20 PM
SEBASTIANTUDON
MEMBER
Checked all the codes all these came back.
Image (Click to enlarge)
Jul 2, 2019 at 9:25 PM
SCGRANTURISMO
I have included all the factory diagnostic troubleshooting guides for all of the Direct Trouble Code(s)DTC(s) that were listed in the picture that you sent. They look like they are all related to each other, so read the guides carefully, as they will explain which are related to which. Once you get one or two fixed they will start to fall like dominoes. Please get back to us with what you are able to find out.
