check engine light is flashing
66,000 MILES
CLMCCARTY
the car is jurking and hesitating.
Apr 30, 2013 at 5:42 AM
JDL
  • 16,098 POSTS
How long since a tune-up? Any applicable trouble codes? Some of the national brand autostore will check codes for free. Can you check fuel pressure?
Apr 30, 2013 at 5:52 AM
CLMCCARTY
I just had a tune-up. I have already had a diagnosis test done they say I have vacuums leaks. They checked them all but no leaks were found. How do I check fuel pressure?
Apr 30, 2013 at 9:12 AM
JDL
  • 16,098 POSTS
You already had it diagnosed at a shop and they couldn't find the problem? No codes or anything? You should have a Schrader valve where you hook-up the fuel pressure gage or tee into the supply line. Just make sure there is no pressure on the system before taking any lines loose.
May 1, 2013 at 12:04 AM
