Check engine light flash on then off
90,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
LONGLEANLADY1
  • 8 POSTS
My check engine light started flashing. I pulled over and turned off the car. I got out and tightened my gas cap. I just refilled. I turned it back on and it was off. The car seems to be running fine. What do you think it could be?
Apr 23, 2020 at 5:46 AM
Good afternoon,
If the light was flashing, it is an indication of an engine misfire. It has nothing to do with your gas cap at all.
There is a code stored for the light and I need that code. A parts store will read the code for free.
How long since you had the plugs changed?
Once I get the code, I can narrow the area of failure for you.
Apr 23, 2020 at 6:12 AM
LONGLEANLADY1
  • 8 POSTS
The code is p057c.
Apr 25, 2020 at 12:44 AM
Okay I attached the code description for you below. This code has nothing to do with the flashing check engine light.
You will need someone with a real scan tool to look at the history codes as I still think you have the misfire issue I listed in my previous post.
Apr 25, 2020 at 1:04 AM
