check engine light does not come on when you turn switch on
150,000 MILES • 0.5L • 4 CYL • RWD • MANUAL
LUMNERCUTTER
Car cranks over but will not start .when you turn the switch on the check engine light does not come on
Oct 30, 2015 at 6:44 PM
WRENCHTECH
  • 20,760 POSTS
That's a pretty good indication that your computer is not powering up. The very first thing you want to check is all your fuses and fusible links using a test light testing both ends of the fuses. If the fuses are all good, then look for main relays. If nothing found you will have to use a wiring diagram a verify all power inputs right at the computer.
Oct 30, 2015 at 9:25 PM
