Check engine light does not come on when you turn switch on
LUMNERCUTTER
MEMBER
2000 TOYOTA CELICA
0.5L
4 CYL
RWD
MANUAL
150,000 MILES
Car cranks over but will not start. When you turn the switch on the check engine light does not come on
Saturday, October 31st, 2015 AT 1:44 AM
WRENCHTECH
MECHANIC
That's a pretty good indication that your computer is not powering up. The very first thing you want to check is all your fuses and fusible links using a test light testing both ends of the fuses. If the fuses are all good, then look for main relays. If nothing found you will have to use a wiring diagram a verify all power inputs right at the computer.
