Check engine light comes on and the turns off when stop and restart it
1992 CHEVROLET 1500
200,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
DEAN.MUNOZ
fires right up, step on gas, has nice power, but as i go, the power isn't there anymore and it stays kind of monotone throughout all the gears slowly.. if i step on it it doesn't go faster it just slowly speeds up. and then after 45 MPH if i step down more i can hear clattering like an old truck does when it overheats. but it's not overheating.
if i cruise, it's fine, but when i try to get ahead of traffic i can hear it clicking like the lifters making noise (check engine light comes on). it's only after a certain speed it does this , but i can cruise all day everywhere. the power is just not there. and when i restart engine light is gone.
Jul 10, 2021 at 10:30 AM
  • 110,244 POSTS
What you described sounds like a plugged catalytic converter. Do me a favor. Take a look through this link and let me know if it seems to mirror what you experience:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Also, I need you to check for diagnostic trouble codes. This truck has an OBD1 system and doesn't require a scanner to get codes. All you need is a short jumper wire or even a paper clip will work. Follow the directions in the following link:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Do that and let me know what codes are retrieved. Also, let me know if the catalytic converter symptoms seem to mirror what you experience.
Jul 10, 2021 at 3:17 PM
