Check engine light on codes
200,589 MILES • 4.7L • V8 • 2WD • AUTOMATIC
RACHDOG
Check engine light recently turned on. I tried checking what it meant but i got as far as 8 quick flashes and second question same car but 9 quick flashes. can someone please help with this problem? any help is highly appreciated.
Aug 19, 2020 at 5:06 PM
Good morning,
They are not codes at all. That is an indication of codes but there needs to be a scan tool used to read the actual codes.
Parts stores will read the codes for free but you need to find one that has the scan tool for OBD 1 systems.
How does the engine run? Is there any issues?
Aug 19, 2020 at 8:25 PM
