Code light came on had O'Reilly's read it and they told me it was lean code. They suggested I use some really good fuel additive called Seabreeze. I put can in and filled tank to 1/2 full. 50 miles later the light went off. Today after using up 1/2 of that fuel, down to 1/4 tank now, the light came back on with same code. Now they suggest I change the fuel filter. Is there something else I should be doing instead?
Nov 19, 2015 at 1:51 PM
