Check engine light code p2099
61,800 MILES • 5.3L • V8 • 4WD • MANUAL
THANH808
  • 8 POSTS
Hi everyone! My SUV has code (p2099 ). The check engine light is sometimes off and sometimes on. anyone have this kind problem before? please help me out! Thank you lots!
Nov 20, 2016 at 11:43 AM
HMAC300
  • 48,601 POSTS
if you have an aftermarket air filter like a K&N or one of those types can cause or modified the exhaust can cause it as well. If aftermarket air filter clean but do not put so much oil in it and look for air leaks prior to system. Also, if O2 sensor replaced put a Delco in it. see picture.
Nov 20, 2016 at 11:42 PM
