Check Engine Light Code P0031
42,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
BMAC168
The check engine light came on and came back with the code p0031. I replaced the O2 sensor, bank 1 sensor 1, but the code still came back and the check engine light will not go away.
Jun 29, 2016 at 8:40 AM
good evening.
what kind of sensor did you use? it is a special sensor called an air fuel ratio sensor. if a standard sensor is used, it will not work.
Jun 29, 2016 at 11:17 AM
BMAC168
Yes, I replaced it with the air fuel ratio sensor. I bought it from a Toyota parts store with part number 89467-06030. It is the oem sensor, so I do not understand why the code will not go away. I cleared it many times, but the check engine light and the same code will pop back up within a minute.
Jun 30, 2016 at 6:28 AM
  • 110,248 POSTS
Are there any wiring issues to the sensor? There are many things that could cause the problem. For example, a bad connection, poor ground, bank 1 sensor 1 circuit fuse, or even a bad ECM. What you need to do is get your hands on a real time scanner which will allow you to watch how the sensor is reacting. That way you will know if there is even a signal from it. Please keep in mind, this is a heated sensor. The code indicates the heater component is experiencing low voltage. To me, that sounds like a connection problem or damaged wiring. Take a look at the pic I found.
Jun 30, 2016 at 1:05 PM
