Check engine light came on
102,000 MILES • 2.4L • 4WD • AUTOMATIC
SAR9MM
The code reader shows
$7e8 and $7e9
What do they mean and is it safe to drive to my mechanic which is 75 miles away?
Aug 1, 2020 at 11:03 AM
  • 110,248 POSTS
That isn't a trouble code. I believe it is scanner component id. When you did this, what took you to that code?
Here is a video showing how to scan a car's computer. See if it helps. I think you are missing a step in the process or not going far enough.
https://youtu.be/YV3TRZwer8k
Aug 1, 2020 at 5:29 PM
