Check Engine Light and Trac off lights are on
LEXUSOWNER123
High RPM's at low speeds
Problem comes and goes- Toyota tech said it was knock sensor #2 that was out, I had both replaced- lights went off- 8 days later, they are both back on
What do you think could be the problem and how serious is it?
Oct 7, 2013 at 10:54 AM
  • 110,251 POSTS
I have to be honest, I'm not sure what a knock sensor would do to cause high rpm's at a low speed. Is the transmission shifting properly?
Oct 7, 2013 at 1:00 PM
  • 110,251 POSTS
Another thought... Have you had the computer scanned to determine if it is the same trouble code or perhaps a new one?
Oct 7, 2013 at 1:01 PM
