Check engine light and tire pressure light won't go off
45,000 MILES
KENZEYMEIZ
I have a 2012 camry hybrid with 45,000 miles on it. 3 weeks ago I hit a metal post hard which caused a 6 inch crack on the lower driver side of the bumper. The next day the check engine light came on and so did the tire pressure light. I took the car to 3 different mechanics and all can not find any mechanical issues with it, they reset the light and send me on my way 3 hours later the light comes on. I am going crazy! I finally found another mechanic that claims the evaporator or sensor was damaged because of the small hit on the bumper. Can this be possible?
Aug 10, 2013 at 7:22 AM
WRENCHTECH
  • 20,760 POSTS
Certainly not the evaporator because that is behind the dash. You'll have to be more specific about what sensors you are referring to.
Aug 10, 2013 at 8:02 AM
KAKANDE RONALD
  • 7 POSTS
may be he meant a condenser and an a/c pressure switch/sensor!
Jan 28, 2020 at 3:39 AM
KAKANDE RONALD
  • 7 POSTS
U need to get the car scanned for fault codes
Jan 28, 2020 at 3:41 AM
