check engine light and maintenance light on
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAKE492014
Both the check engine light and maintenance are on. The cigarette lighter does not work, the fuel indicator light stopped working, the auto drive does not work and the right side front passenger auto-lock make a loud noise when engaging.
May 11, 2014 at 9:01 AM
ok, you need to have the code pulled for the check engine light. they do this for free.
the maintenance reminder light needs to be re set. the procedure is in the owners manual
check all fuses with a test light for the lighter.
the dash needs to be removed to access the light bulb for the fuel light.
the power door lock acuator sounds like it is worn out and needs to be replaced
May 11, 2014 at 10:26 AM
