Check engine light and battery light.
170,000 MILES
MIKEBEC
Our check engine light came on and a few weeks later the battery light would also come on periodically. The alternator was replaced last month. and the auto parts store says the light codes showed it as a transmission issue. Not sure how the 2 lights correlate. Please help.
Mar 4, 2016 at 1:59 PM
WRENCHTECH
  • 20,758 POSTS
The battery light is an indication that the battery is not being recharged.
The "check engine" light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious, but still a problem and needs to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. Those codes will give you specific information about what the computer saw and will get you pointed in the right direction to find your problem. With a 1996 or newer and some 1995 cars and you have an AutoZone or Advanced auto parts in your area, they will read them for free. Once you have these code numbers, we can be a lot more specific about what your problem may be.
Mar 4, 2016 at 10:21 PM
