Check engine light always on flashes randomly
280,000 MILES • 4.6L • V6 • AUTOMATIC
MISTY1984
So my check engine light stays on all the time but sometimes while driving it will start to flash. the car will start chugging and the A/C will even start blowing out warm air. this only lasts for less than a minute in the light will stop flashing in the car goes back to normal.
Sep 17, 2019 at 5:19 AM
SCGRANTURISMO
  • 4,897 POSTS
When the Malfunction Indicator Lamp (MIL) or "check engine" light is illuminated that means that a Direct Trouble Code (DTC)(s) have been set. When the MIL starts flashing this indicates that a Type A, or a catalyst damaging event is taking place. This is a serious DTC that needs to dealt with immediately or serious engine/transmission damage can occur. Can you please pull the DTC(s) for me. Here is a link below for you to go to explaining how to do that:
Thanks,
Alex
2CarPros
Sep 17, 2019 at 6:23 AM
