Check engine light
154,000 MILES • 0.6L • V8 • 4WD • AUTOMATIC
H2HUMMER12
What do the following codes mean:
0030
053
134
135
300
422
Feb 17, 2017 at 7:56 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Okay, So the P0030, P0053, P0134, P0135 & P0422 all have to do with the O2 sensors mainly sensor 1 bank 1. They are heated sensors and have fuses, I would look for the fuse block under hood and find the related fuse for sensor 1 check to see if it is blown.
The P0300 is multi-cylinder misfire - when was last tune up could also be do to O2 sensor issue.
Hope this helps.
Mark
Feb 17, 2017 at 8:54 AM
CARADIODOC
  • 34,406 POSTS
Are these in the Engine Computer? If so, the first four are all related to problems with the driver's side front oxygen sensor.
P0300 indicates a random cylinder misfire.
I do not have a listing for P0422. The closest is P0420 which refers to low efficiency of the catalytic converter on the driver's side.
OBXAUTOMEDIC
  • 3,711 POSTS
Here is the fuse block diagram.
Feb 17, 2017 at 9:18 AM
