Check engine light
375,000 MILES • 4.0L • V6 • 2WD • MANUAL
RYAN REYNA
Need to get my truck smogged but the check engine lights on. cannot seem to find a service book for it either, so i have no clue where to look for the code reader or read the thing when i do find it.
Nov 14, 2017 at 4:32 AM
KHLOW2008
  • 41,812 POSTS
Yours is OBD-I and the diagnostic connector should be in engine compartment., either near the battery, fuse box or air-cleaner
It should be a small black box with a cover that is flipped open, to show something like the diagram.
Nov 14, 2017 at 1:15 PM
HARRY P
  • 2,292 POSTS
Most areas will not do a smog check on anything older than 1996 (When OBD2 was made the federal standard). Are you sure that they are going to scan it?
Nov 14, 2017 at 6:48 PM
