Check engine light does not turn on?
120,987 MILES • 5.4L • V8 • 2WD • AUTOMATIC
TOMMY L SHERIDAN JR.
Went to smog it everything passed but my check engine light doesn't come on.
May 1, 2021 at 5:55 AM
  • 110,248 POSTS
Chances are the bulb is bad or loose. To access the bulb, you need to remove the cluster and take it apart. If you look at the attachments below, they explain specifically how it's done.
May 2, 2021 at 11:54 AM
VIOLETLILA
this is where I bought my bulb https://parts.allmoparparts.com/search?search_str=bulb for my Dodge and other OEM parts.
May 5, 2021 at 11:18 AM
  • 110,248 POSTS
Thanks for the input. It's appreciated and will likely help others.
Take care and come back anytime.
May 5, 2021 at 12:23 PM
