Check engine light
195,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
JLEBARON
My rodeo idols low and will stall out got it checked to see what codes popped up
P0174
P1125
P1295
P1120
P0171
P0300
P0174
P0171
P0300
The guy that checked for codes said all these codes can be related to one problem
The suggested part was intake manifold gasket
Has any one experienced these issues ?
Apr 5, 2016 at 8:18 AM
SATURNTECH9
  • 30,869 POSTS
For the P0171 and P0174 and p0300 lean banks and random misfire the number one fix is intake gasket.But for the p1125 and p1295 those are throttle control codes it says check the engine wire harness under the intake manifold for being damaged by Heat.Also the code P1120 is for the throttle position sensor.The number one fix for that code is a bad throttle position sensor.That sensor can set the p1125 and p1295 codes as well.you would still have to check for a vacuum leak and I would check the throttle position sensor using live data readings on a scan tool or code reader .
Apr 7, 2016 at 12:33 PM
