Check engine light, acts like it wants to stall or shut off at idle
87,000 MILES • 4 CYL • TURBO
AMANDA DUKE
Check engine light came on. AutoZone said failing turbo and map sensor. Replaced map sensor, air filter, changed oil, filled gas tank. Poor performance, car wants to stall or shut off at idle.
Jan 3, 2019 at 6:40 AM
Good evening,
What were the codes you had?
https://www.2carpros.com/articles/engine-has-low-power-output
Remember, AutoZone employs salesman not technicians.
https://www.2carpros.com/articles/symptoms-of-low-engine-power
Lets start with the codes.
Jan 3, 2019 at 8:02 AM
