Check engine light on?
2021 NISSAN SENTRA
48,000 MILES • 2WD • AUTOMATIC
JRP89
May be has related, but has a check engine light appear after filling tank a bit. Proceeded to rescrew gas cap to make sure it was on tight. Saw light on for a bit. Opened the car hood to see if anything looked off and when I turned the vehicle back on, the light now appears off.
Sep 25, 2024 at 12:14 AM
STEVE W.
  • 15,344 POSTS
Sounds normal. If the cap doesn't seat properly it can leak enough to trigger an EVAP code. Those will turn the light on and on modern vehicles like yours it is a constant test so when you tightened the cap it sealed and the test passed and the light went off as a result.
Sep 25, 2024 at 8:58 AM
JRP89
Sep 26, 2024 at 6:53 AM
STEVE W.
  • 15,344 POSTS
You're welcome.
Sep 26, 2024 at 7:37 AM
