Check engine light
114,009 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JRAY1987
  • 7 POSTS
My check engine light has been on for awhile. Not blinking just on. I had the code read and it was the same code as if the gas cap was loose. Changed the gas cap. Did not solve the problem. My truck started spitting and sputtering so I used Seafoam in the vacuum line to clean out the trash, used Lucas fuel treatment, and replaced the MAF sensor. Truck went back to running smooth. Disconnected the battery to reset the check engine light. The next day the light came back on. I read that it may take up to eight times before the computer would recognize the part had been changed. So I reset the light again by disconnecting the battery cables. Light went off yesterday but while driving it this morning the light came back on. Is it possible the computer has not recognized the new part? Or might there be another issue?
May 14, 2018 at 3:19 AM
Good afternoon.
First thing is we need the code to help you narrow the area of failure.
No to that eight times thing. That is not true.
My suggestion is to stop resetting and throwing parts with no results. lets get to the root cause of the failure.
https://www.2carpros.com/articles/check-engine-light-clear-codes
May 14, 2018 at 6:47 AM
JRAY1987
  • 7 POSTS
The code it gave was the code it gives like if your gas cap is not screwed on tight or mass air failure etc., basically getting air into the engine that is not supposed to be there. I do not know the exact code. I will have to go get it diagnosed again. I do not have time to get it done today. It may be tomorrow before I can get the code.
May 14, 2018 at 7:18 AM
JRAY1987
  • 7 POSTS
And it was not the gas cap. I have already replaced my gas cap.
May 14, 2018 at 7:19 AM
There are too many EVAP codes to guess. Get it checked again for the code and get back to us with the code numbers.
May 14, 2018 at 7:20 AM
JRAY1987
  • 7 POSTS
Had the code read and it gave the P0449 code.
May 15, 2018 at 6:36 AM
Okay, in most cases the vent valve is the failure but needs to be checked to confirm.
DTC P0443 or P0449
Diagnostic Instructions
* Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Vehicle > Initial Inspection and Diagnostic Overview
* Review Strategy Based Diagnosis for an overview of the diagnostic approach.
* Diagnostic Procedure Instructions provides an overview of each diagnostic category.
DTC Descriptors
DTC P0443
- Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0449
- Evaporative Emission (EVAP) Vent Solenoid Control Circuit
Diagnostic Fault Information
Circuit/System Description
An ignition voltage is supplied directly to the evaporative emission (EVAP) canister purge solenoid valve. The engine control module (ECM) grounds the EVAP canister purge solenoid valve control circuit through an internal switch called a driver. The ECM monitors the status of the driver. The EVAP canister purge solenoid valve is pulse width modulated (PWM). A scan tool will display the amount of ON time as a percentage.
Battery voltage is supplied to the EVAP canister solenoid valve. The ECM grounds the EVAP canister vent solenoid valve control circuit through an internal switch called a driver. The ECM monitors the status of the driver. A scan tool will display the commanded state of the EVAP canister vent solenoid valve as ON or OFF.
Conditions for Running the DTC
* The ignition is ON.
* The system voltage is between 9-18 volts.
* DTCs P0443 and P0449 run continuously when the above conditions are met.
Conditions for Setting the DTC
The ECM detects that the commanded state of the driver and the actual state of the control circuit do not match for a minimum of 5 seconds.
Action Taken When the DTC Sets
* DTC P0443 is a Type B DTC.
* DTC P0449 is a Type A DTC.
Conditions for Clearing the MIL/DTC
Circuit/System Verification
P0443
1. Ignition ON, engine OFF, you should hear a clicking sound when the EVAP canister purge solenoid valve is commanded to 50 percent with a scan tool. The clicking sound should stop when the EVAP canister purge solenoid valve is commanded to 0 percent. The rate at which the valve cycles should increase when the commanded state is increased, and decrease when the commanded state is decreased.
2. Operate the vehicle within the Conditions for Running the DTC to verify the DTC does not reset. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
P0449
1. Ignition ON, engine OFF, command the EVAP vent solenoid ON and OFF with a scan tool.
2. Listen for a click when the valve operates. Verify that both the ON, and the OFF states are commanded.
3. Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle within the conditions that you observed from the Freeze Frame/Failure Records data.
Circuit/System Testing
1. Ignition OFF, disconnect the harness connector at the EVAP canister purge or vent solenoid valve.
2. Ignition ON, verify that a test lamp illuminates between the voltage supply circuit terminal A and ground.
^ If the test lamp does not illuminate, test the voltage supply circuit for a short to ground or an open/high resistance. If the circuit tests normal and the voltage supply circuit fuse is open, test or replace the EVAP canister purge solenoid.
3. Connect a test lamp between the voltage supply circuit terminal A and the control circuit terminal B.
4. Command the EVAP canister purge solenoid valve to 50 percent with a scan tool, or the EVAP canister vent solenoid valve ON and OFF. The test lamp should respond to the command.
^ If the test lamp is always ON, test the control circuit for a short to ground. If the circuit tests normal, replace the ECM.
^ If the test lamp is always OFF, test the control circuit for a short to voltage or an open/high resistance. If the circuit tests normal, replace the ECM.
5. If all circuits test normal, replace the appropriate solenoid valve.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests
* Evaporative Emission Canister Purge Solenoid Valve Replacement
* Evaporative Emission Canister Vent Solenoid Valve Replacement (15 Regular Cab) Evaporative Emission Canister Vent Solenoid Valve Replacement (15 Ext/Crew Cab) Evaporative Emission Canister Vent Solenoid Valve Replacement (25 Ext/Crew Cab w/6 Ft Bed) Evaporative Emission Canister Vent Solenoid Valve Replacement (15/25 Reg/Ext/Crew Cab w/8 Ft Bed) Evaporative Emission Canister Vent Solenoid Valve Replacement (35 Reg/Ext/Crew Cab w/8Ft Bed)
P0449
Item Description
Symptom/DTC P0449
Descriptor
Probable Causes
Engine Control Module (ECM)
K20 Engine Control Module (ECM)
May 15, 2018 at 6:42 AM
JRAY1987
  • 7 POSTS
If it helps any, when I am pumping gas I cannot hold the gas nozzle wide open. It will keep kicking off. I have to wait a few seconds after putting the nozzle in the gas cap and then run it at half speed.
May 15, 2018 at 7:12 AM
The valve is a normally open valve. It is commanded closed when the EVAP system is doing its internal test. The valve is not closing causing a large leak.
May 15, 2018 at 7:24 AM
JRAY1987
  • 7 POSTS
So we are talking about changing the solenoid?
May 15, 2018 at 7:33 AM
No, it is part of the vent valve. You can get it at a parts store.
https://www.rockauto.com/en/catalog/gmc,2008,sierra+1500,5.3l+v8,1441178,exhaust+&+emission,vapor+canister+vent+valve+/+solenoid,16992
May 15, 2018 at 7:38 AM
JRAY1987
  • 7 POSTS
Single port or dual port?
May 15, 2018 at 8:00 AM
It has two ports. One hose goes to the canister and one to outside air.
There is a two wire connector to the solenoid.
May 15, 2018 at 8:03 AM
