code po171 engin to line 1st bank,to much air not enough gas.
how do i correct this problem.
Apr 21, 2013 at 9:22 AM
WRENCHTECH
✓Experienced Mechanic
That code indicates the 0/2 is indicating lean. That can be caused by a number of different things Vacuum leaks, fuel pressure, fuel injectors, bad 0/2, etc, etc
