Code p0171 I, check engine light car is idling rough?
157,342 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
KAYLEEPOE5590
My car is idling rough when I put it in reverse. If the A/C is on it does if I been driving for a few miles with A/C on and come to a stop light, it idles rough and then does and it smells like I have an exhaust leak. the code that It gave was p0171 I think but the guy said system running too rich not sure he said o2 sensor or MAF sensor.
Jul 9, 2025 at 2:50 PM
  • 55,746 POSTS
So the system thinks the exhaust is lean, so it wants to add fuel, this is why you get the smell. This can be caused by the engine misfiring, or you have a leaky fuel injector which would cause double trouble (misfire and stinky exhaust).
P0171 - System Too Lean (Bank 1)
I would go over these guides, both will help you understand what is going on. Then I would remove the spark plugs and look for one that is black, this will be the cylinder that is having the issue.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Does your engine have an exhaust leak? This can cause the computer to run rich.
This goes over the reasons for a misfire, but I can walk you through the steps to fix it if you get back to me on the spark plug condition. Check out the images (below). Please upload pictures or videos in your response.
Jul 10, 2025 at 5:57 AM
MECHTRIX
  • 593 POSTS
This code po171 is to indicate that there's a lean condition here's a list of a few things that can cause this condition
1..A vacuum leak ..check all hoses boots etc., to see if any are disconnected or cracked ..split or damaged leaking .
2..A leaky intake manifold or other related components.
3..a leaky brake booster or booster hose.
4..A bad MAF sensor
5.. A bad o2 sensor
6..A fuel system problem
"Good luck hope this helps " .
Jul 10, 2025 at 6:08 AM
KAYLEEPOE5590
I have read both responses hadn’t had time to check the car it’s self how eve since asking the w questions I've noticed my car sounds louder then normal the cat under the hood has a bad smell of exhaust coming from it an my engine coolant by pass hose that comes off the thermostat to the endgame head is spraying coolant right wheee the clamp holds it on how hard is that to change ??? Also I will upload any pics an videos as I go on your reply’s here’s the coolant leak video an in the video you can kind of see the cat that has the exhaust smell coming from it.
Jul 12, 2025 at 10:55 AM
KAYLEEPOE5590
Hose leaking coolant under my engine block.
Jul 12, 2025 at 10:57 AM
MECHTRIX
  • 593 POSTS
Yep its a pretty easy fix. Most likely the coolant is spraying out and dripping down onto the cat and the rest of the hot components down there that's where the smell would be coming from its burning the coolant off might smell a little sweet but that should go away once you replace that hose and that should be done right away without hesitation and i wouldn't drive the car anymore until its repaired on that note the good thing is while you're doing it you might find some of the other things i meantime since you be up close in there for a few minutes. hope this helps "good luck "
Jul 12, 2025 at 2:42 PM
