Check engine light
65,000 MILES • 2WD • AUTOMATIC
LAKEEKA
Hi, a few months ago a check engine light came on my car. Firestone ran diagnostic codes and replaced canister purge valve, vent shut valve and intake hose assembly. After about a month check engine light came on again, they ran the codes and replaced my fuel cap. Again the car was fine for a month or so and the light came on again. They ran the codes again and they said i have a faulty fuel tank pressure sensor and replaced that. That was last week and today the light came on again! Before I take it back to the shop I was hoping to figure out of they are just ripping me off by having me replace all these parts or is it really possible that all these parts are failing in such rapid succession? It seems incredible to me that all of these parts need replacing. Is it possible they are misdiagnosing the problem? Is it possible i just have a faulty check engine light sensor? thanks
Sep 11, 2016 at 9:21 PM
WRENCHTECH
  • 20,760 POSTS
We would need the exact code number to tell you how to proceed from here.
Sep 11, 2016 at 9:33 PM
LAKEEKA
P0455.
Sep 13, 2016 at 1:53 AM
WRENCHTECH
  • 20,760 POSTS
That is a leak code and a large one at that. What needs to be done and what should have been done right from the beginning is to do a smoke test to find the leak. It appears they have been simply guessing and throwing parts at it.
Sep 13, 2016 at 5:54 AM
