Check Engine Light code was P2A01?
189,000 MILES • 4 CYL • 2WD • AUTOMATIC
RPJ
  • 109 POSTS
The C.E. light was on in my vehicle and a local parts store checked it and the code was P2A01 signaling an O2 sensor issue.
The CE light was on for about 14 days and suddenly went out on 11/8/25. Should I still have a shop look at this or wait until the light comes back on.
Thanks,
Roosevelt.
Nov 9, 2025 at 8:40 AM
  • 55,709 POSTS
I would clear the codes and wait until the light comes back on. This might be a glitch in the system or the car has traveled up a long hill, if the code comes back replace the oxygen sensor behind the catalytic converter and clear the code again which should fix the problem. This guide can help walk you though the repair
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Please go over this guide and get back to us.
Nov 11, 2025 at 2:11 AM
RPJ
  • 109 POSTS
Thank you very much Ken! I always appreciate your help.
I'll let you know what happens.
Roosevelt.
Nov 11, 2025 at 3:57 AM
  • 55,709 POSTS
No problem, we are here to help :)
Nov 12, 2025 at 3:26 AM
