Check engine light
189,000 MILES • 2.3L • 4 CYL • TURBO • AUTOMATIC
AVIS ABRAM
Please tell me how many times do you change out the DSI and the thermostat and coolant temperature sensor I have the vehicle listed above 95ser 2.3T. she has 189,000 miles on her and I regularly get the her serviced. For the pass three years I have had to replace this same part mostly in the winter time. please help.Thanks
Jan 29, 2019 at 11:37 PM
STEVE W.
  • 15,418 POSTS
Normally you might change those parts once through the life of the vehicle. If they are actually failing that often there is probably another problem causing their failure. Something like a bad engine ground or wiring fault causing issues in the system.
Do you get to see the "bad" parts or have a picture of them so we could see how they failed?
Jan 30, 2019 at 12:08 AM
AVIS ABRAM
Okay.
No I haven’t seen the old parts.
I’m going to Saab today to have them check it again.
Per Autozone same code Thermostat.
This Saab tech is the only guy I have service my car he’s pretty reliable.
Jan 30, 2019 at 2:01 AM
STEVE W.
  • 15,418 POSTS
What is the actual code are they getting, not their translation? Where have you been buying the parts?
Jan 30, 2019 at 6:55 AM
