Check engine light turned on and then turned off three days later?
173,000 MILES • 6 CYL • 2WD • AUTOMATIC
SBHUY
The light came on and went off after 3 days. ran a diagnostic while it was on catalytic converter warning. get it fixed right away or wait?
Feb 16, 2023 at 10:36 AM
  • 110,248 POSTS
Do you remember the code? Was it a P0420 or P0430? Let me know that. If it was, they indicate the converter is working below the threshold. As long as you are not experiencing a power loss, you should be okay, but it will keep turning the lamp back on if cleared.
Here is a link you may find of interest:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Let me know the code so I can better help.
Feb 16, 2023 at 1:09 PM
SBHUY
The code was PO420. No experience of power loss.
check engine light has not come back on, but not sure how long it stays off if the converter is bad.
Feb 17, 2023 at 1:23 AM
  • 110,248 POSTS
The P0420 indicates the catalytic converter is working below a specific threshold. Basically, it isn't doing what it should. Usually, this code leads to the need to replace the converter.
On the other hand, I've seen them come on and then the light goes out for years. Since you are not experiencing a power loss, I'm not concerned about it being partially plugged. At this point, continue driving it. If the light returns with the same code, we will need to replace it. Also, if there is no power loss, it won't damage anything if the same code returns. However, it will fail an emissions test (not sure where you are located). Also, I would run it for a long time that way. It will affect the fuel mileage and performance to a degree.
Let me know your thoughts and what I can do to help.
Feb 17, 2023 at 12:18 PM
