check engine light single flash and pause then 12 flashes, what does this mean?
94,897 MILES • 1.5L • 4 CYL • AUTOMATIC
BRH28
  • 6 POSTS
I wanted to know how to determine what a single flash and pause then 12 flashes means and then pauses and repeated 12 flashes i sat there for about 10 minutes so i might be wrong as well about this. i am not sure how long it takes to sit there and count them or when it will restart the flashes all over again but I'm not sure what it means. Also, Honda told me that the flashes i counted when i made the light come on aren't the real codes but that when the light comes on, on its own that's when the codes are the right ones? but i am 90 percent sure they were the same both ways today. i am not experienced in this so i could honestly have counted wrong and not sat there long enough so i can always try again. i hope i make sense.
Dec 2, 2024 at 2:00 PM
  • 55,711 POSTS
Here is the correct way to retrieve the codes and their meaning:
Code 12 Exhaust re-circulation system
https://www.2carpros.com/articles/honda-car-1990-1995-obd1-code-retrieval-procedure-and-definition-table
Please let me know if you have any questions. Ken
Dec 3, 2024 at 3:02 AM
BRH28
  • 6 POSTS
Thank you. does it matter if the light comes on by itself or is the code going to be the same either way? I had the EGR checked out and they said it looked fine, but I can always get second opinions on this.
Dec 3, 2024 at 6:13 AM
  • 55,711 POSTS
It could be the valve is okay but the vacuum lines that go to it are bad, I would check those next.
Dec 4, 2024 at 1:49 AM
