check engine light
90,000 MILES • V8 • 2WD • AUTOMATIC
JDHAYES
pull codes all codes 02 related circuit and 2 sensor, 1 sensor 1, and 2 sensor, 1 sensor 2 on. how it is real code for every sensor?
Jun 29, 2017 at 2:57 PM
CARADIODOC
  • 34,414 POSTS
You need to know the exact fault code numbers. There's a bunch of them, and they mean very different things. When you have a lot of codes suddenly show up at the same time, look for what they have in common. In this case the wiring harness is a real good suspect. Look for wires that fell down onto hot exhaust parts, or corroded connector terminals.
Jul 1, 2017 at 12:29 PM
