Check engine light
171,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
BOISVERT808
  • 6 POSTS
when i start the car and drive it runs fine. if i have to stop somewhere and then restart the car the check engine light starts flashing and the car runs horrible. it loses power, it will buck and shake. Once the car has been off for awhile i'll start it and it us perfectly fine. I have changed the plugs and coil pack. Is this a clogged fuel filter possibly?
Oct 30, 2019 at 3:29 AM
  • 110,251 POSTS
Welcome to 2CarPros.
It sounds like it is heat related. Does it do this when cold? The flashing check engine light indicates a misfire. The first thing that comes to mind is a crankshaft position sensor. When they start going bad, heat affects them. Take a look through these links and let me know if it seems to mirror what you are experiencing.
________________
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
_______________
If this seems like the problem. Here is a link that shows in general how it's replaced:
_____________
Here are directions specific to your vehicle for replacement. The attached pictures correlate with the directions.
2006 Jeep Truck Liberty 4WD V6-3.7L VIN K
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Service and Repair Procedures
PROCEDURES
REMOVAL
pic 1
The Crankshaft Position (CKP) sensor (2) is mounted into the right rear side of the cylinder block. It is positioned and bolted into a machined hole.
1. Raise vehicle.
2. Disconnect sensor electrical connector.
3. Remove sensor mounting bolt (1).
4. Carefully twist sensor from cylinder block.
5. Check condition of sensor O-ring (3).
INSTALLATION
pic 2
1. Clean out machined hole in engine block.
2. Apply a small amount of engine oil to sensor O-ring (3).
3. Install sensor (2) into engine block with a slight rocking and twisting action.
CAUTION: Before tightening sensor mounting bolt, be sure sensor is completely flush to cylinder block. If sensor is not flush, damage to sensor mounting tang may result.
4. Install mounting bolt (1) and tighten to 28 N.m (21 ft. lbs.) torque.
5. Connect electrical connector to sensor.
6. Lower vehicle.
___________________
Also, I strongly recommend having the computer scanned to identify diagnostic trouble codes. Most parts stores will do it for free.
Let me know what you find.
Oct 30, 2019 at 12:56 PM
BOISVERT808
  • 6 POSTS
It does not do it when it’s cold. I can start the car in the morning and drive 35 minutes to work and the car runs fine. Same thing when I go home, no problem at all. It’s always when I restart the car when it’s still warm that I have the problem. It also make a humming noise when it acts up. Does this still sound like the same issue you mentioned? Thanks
Oct 30, 2019 at 5:52 PM
BOISVERT808
  • 6 POSTS
it does seem like this could be the problem but i have no problem starting my jeep and it has never stalled. it sounds like it wants to stall sometimes but it hasn't yet. But like i said before i drive 22 miles to work and it runs normal. When it is acting up it still starts without hesitation but it does make a humming noise when it is warm.
Oct 30, 2019 at 9:38 PM
  • 110,251 POSTS
Welcome back:
I understand what you are saying. Have you retrieved diagnostic trouble codes? There could be more than just a misfire code. If you have, let me know what they were. Also, some general questions. Have you checked fuel pressure or have you checked to make sure there are no vacuum leaks?
Oct 31, 2019 at 12:32 PM
BOISVERT808
  • 6 POSTS
I plan to go either today or tomorrow to have it scanned. I will let you know what the codes are. I have not checked fuel pressure or vacuum leaks yet.
Oct 31, 2019 at 8:17 PM
  • 110,251 POSTS
Welcome back:
I will watch for your reply. If you decide you want to check for vacuum or fuel pressure issues, here are a couple links you may find helpful:
Take care and have a good weekend.
Nov 1, 2019 at 1:47 PM
BOISVERT808
  • 6 POSTS
I did have it scanned and it came up as code PO201. A bad fuel injector or wire. Bought both yesterday and my husband will put in today. Hopefully that solves the problem.
Nov 1, 2019 at 5:08 PM
  • 110,251 POSTS
Welcome back:
That's a cylinder 1 injector. If the injector doesn't fix the issue, check for power to the injector. See pic 1 Let me know what you find.
_________________________
Here are the directions for replacing the injector. Thought I would add them.
Fuel Injector
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Injector Service and Repair Procedures Fuel Injector
FUEL INJECTOR
REMOVAL
pic 2
1. Remove fuel rail.
2. Disconnect clip(s) (2) that retain fuel injector(s) (3) to fuel rail (4).
INSTALLATION
pic 3
1. Install fuel injector(s) (3) into fuel rail assembly (4) and install retaining clip(s) (2).
2. If same injector(s) is being reinstalled, install new O-ring(s). Two different O-rings are being used. These can be easily identified by color. Install black O-ring at intake manifold end of injector. Install red/rust colored O-ring at fuel rail end of injector.
3. Apply a small amount of clean engine oil to each injector O-ring. This will aid in installation.
4. Install fuel rail.
5. Start engine and check for fuel leaks.
________________________________________
Make sure to replace the o-rings on the injector as well. I always lubricate them with a small amount of Vaseline before I install them. It helps prevent damage to the o-ring.
Let me know how things turn out for you.
Nov 2, 2019 at 5:38 PM
BOISVERT808
  • 6 POSTS
Both the injector and connector wire were replaced and Jeep runs great again. The connector was toast, probably what the issue was instead of the injector. But back to normal. Thanks for all the input!!
Nov 4, 2019 at 6:17 AM
  • 110,251 POSTS
That's great news and you are very welcome. I'm glad it's going again. And I agree with you. Chances are the injector was fine. Regardless, it's fixed.
Take care and let us know if you have questions in the future.
Nov 4, 2019 at 12:49 PM
