I had codes for a cylinder misfire and running too lean. I then replace the spark plugs and wires along with the mass airflow sensor I cleared the check engine light and the code P1614 turn the check engine light back on. I can’t remember if that was one of the codes before but it doesn't look familiar..
Apr 7, 2021 at 2:00 AM
