Check engine light is still on even after I fixed the issue
2009 CHEVROLET AVEO
45,000 MILES • AUTOMATIC
AWA9256
My oil was low and I had no antifreeze so that's why it would heat up fast. As soon as the issue arose I pulled over and refilled them but today is day 2 and it's still the same. The antifreeze did go down halfway when I stopped for gas then I went straight home where I checked it again and it was full. I'm not sure what's going on. All is great today. It runs normally but the engine light won't go away.
Feb 8, 2020 at 12:27 PM
Good evening,
What is the code for the check engine light? It is not levels of the fluids. The light is a fuel control issue.
https://www.2carpros.com/articles/radiator-pressure-test
https://www.2carpros.com/articles/engine-is-leaking-oil
You need to have the code checked so I can help narrow the area of failure.
https://www.2carpros.com/articles/check-engine-light-top-ten-reasons
Feb 8, 2020 at 3:21 PM
