check engine light on after replacing the battery, how to reset it?
178,000 MILES • 4 CYL • 2WD • AUTOMATIC
TIMBER12
check engine light keeps coming on and off and stayed on after changing battery. What is the problem and how do I reset it?
Dec 19, 2023 at 4:29 PM
  • 110,248 POSTS
Is the vehicle running properly? As far as the check engine light, that indicates there are diagnostic trouble codes stored in the PCM. We need to have it scanned to determine what codes are present. They should point us in the right direction.
Here is a link that shows how to scan the CAN system:
If you don't have a scan tool, most parts stores will check it free of charge.
Let me know if this is something you can have done or do yourself.
Dec 20, 2023 at 1:34 PM
