check engine light
133,000 MILES
ECLASS6
my check engine light keeps coming on. tested and keeps giving code P302 #2 cylinder misfire. car has been tuned up by a volvo service technician (plugs, wires and coils). also engine control temp sensor also replaced and gas cap as well. yet the light keeps coming back. You can't feel a misfire while driving either. Can't afford to keep paying mechanic, what else can I do?
Apr 22, 2013 at 1:50 PM
was the compression checked???
was the injector and related wiring checked???
gas cap has no effect on it.
roy
Apr 22, 2013 at 7:43 PM
ECLASS6
yes the compression was ok and the plugs, wires and coils were replaced. I can't say that the injector it self was actually checked. I guess I should make that the next thing. Is it possible that is something that I can do myself, if so how do I go about it. Also I've been doing some reading and it seem's that this (check engine light) is a common issue with this car. I recently bought it used and wasn't aware of it until now. Thank you very much for your reply.
Elmer
Apr 23, 2013 at 1:13 PM
the light is common on all cars.
do you have a professional injector cleaner???
Apr 23, 2013 at 7:34 PM
