Check engine codes p0132, p0135, p1132, 0p171, p0172, and p0468?
250,000 MILES • 5.4L • V8 • 2WD
DAVID LLOYD111
I have several codes coming I’d like see the full list codes the list of codes p0132 p0135 p1132 0p171 p0172 and p0468.
Jul 11, 2025 at 1:00 PM
  • 55,673 POSTS
Here are the code means for the codes listed.
P0132 - O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1132 - Lack of HO2S Switch - Sensor Indicates Rich (Bank 1 Sensor 1)
P0171 - System Too Lean (Bank 1)
P0172 - System Too Rich (Bank 1)
You have a sensor with the heater that is not good. Is the engine misfiring? This can make the rest of the codes come up. I would pull the spark plugs to see how they look. If one is black and the others are white or light color you have a stuck fuel injector on that cylinder FYI. Let us know how it goes.
Jul 12, 2025 at 4:05 AM
