Check engine code/transmission problem
175,156 MILES • 5.0L • V8 • AUTOMATIC
JAY-12849
  • 5 POSTS
Oil was burnt had to replace oil and oil filter. Drives but won’t shift out of third unless overdrive is off and when I turn it off I get 5-10 minutes of driving before the overdrive light starts flashing. also won’t with the overdrive off. I can only get the vehicle up to 65 before it just starts revving when I try to give it gas. Only trouble code is mass airflow sensor, but replaced it yesterday and still gives same trouble code.
Oct 5, 2020 at 10:18 AM
  • 110,248 POSTS
Is it the transmission fluid that was burnt? Also, can you provide the diagnostic trouble codes you retrieved? Was the problem evident prior to servicing the transmission?
Oct 5, 2020 at 11:44 AM
JAY-12849
  • 5 POSTS
No it was the oil, and no I took it to AutoZone and used theirs.
Oct 5, 2020 at 1:29 PM
JAY-12849
  • 5 POSTS
Overdrive on vehicle can only get up to 40 and overdrive of vehicle can only get up to 65 but O/D light starts blinking after a while.
Oct 5, 2020 at 1:38 PM
  • 110,248 POSTS
Okay, was the transmission fluid checked for condition and level? I made the assumption that was what was changed. Lets start there. Here are directions for checking level and condition. The attached pics correlate with the directions.
______________________
1997 Mercury Truck Mountaineer V8-302 5.0L VIN P EFI
Fluid Level Check
Vehicle Maintenance Fluids Fluid - A/T Testing and Inspection Component Tests and General Diagnostics Fluid Level Check
FLUID LEVEL CHECK
CAUTION:
- The vehicle should not be driven if the fluid level is below the COLD marked area on the fluid level indicator and outside temperature is above 10° C (50° F).
- If vehicle has been operated for an extended period at high speed, in city traffic, in hot weather, or vehicle is being used to pull a trailer, the fluid has to cool approximately 30 minutes after engine had been turned OFF to obtain an accurate reading.
Under normal circumstances, check the fluid level of the transmission during normal maintenance, and change it at 48,000 km (30,000 miles) since the vehicle does not use up transmission fluid. However, if the transmission is not working properly, the transmission may slip or shift slowly or there may be some sign of fluid leakage. The fluid level should he checked
It is preferable to check the transmission fluid level at normal operating temperature after approximately 32 km (20 miles) of driving. If necessary, check the fluid level without driving the vehicle, if the outside temperature is above 10° C (50° F).
When checking fluid at normal operating temperature, the fluid level should be within the HOT marked area on the fluid level indicator. When the vehicle has not been driven and outside temperature is above 10° C (50° F), the fluid level should be within the COLD marked area on the fluid level indicator.
Check Fluid Level as Follows:
NOTE: The fluid level on the fluid level indicator will be different at operating temperature and ambient temperature. For the correct fluid level reading on the fluid level indicator, follow the appropriate instructions.
1. With the transmission in PARK (P), the engine at curb idle rpm, the foot brakes applied and the vehicle on a level surface, move the transmission range selector lever through each range. Allow time in each range to engage the transmission. Return to PARK (P), apply the parking brake and block the wheels. Do not turn off the engine during the fluid level check.
2. Clean all dirt from the transmission fluid level indicator cap before removing the fluid level indicator from the fluid fill tube.
3. Pull the fluid level indicator out of the fluid fill tube, wipe it clean, and push it all the way back into the tube. Make sure it is fully seated.
pic 1
4. Pull the fluid level indicator out of the fluid fill tube again and check the fluid level.
If necessary, add enough fluid through the transmission fluid fill tube to raise the level to the correct position. Do not overfill the transmission. This will result in foaming, loss of fluid through the vent and possible transmission malfunction. If overfill occurs, excess fluid must be removed.
5. Install the fluid level indicator, making sure it is fully seated in the fluid fill tube.
If the transmission fluid level is checked when the fluid is at ambient temperature, the fluid level indicator could indicate that fluid should be added if the fluid level indicator is misread. If fluid is added at this time, an overfill condition could result when the fluid reaches operating temperatures of 66° C-77° C (150° F-170° F) (fluid level indicator hot to touch).
Underfill can result in transmission loss of engagement or slipping. This condition is most evident in cold weather or when the vehicle is parked or being driven on a hill.
If the transmission fluid level is correctly established at 10-35° C (50-95° F), it will appear in the HOT marked area on the fluid level indicator when the transmission reaches an operating temperature of 66-77° C (150-170° F). Do not overfill or underfill.
_______________________________________________________
Fluid Condition Check
Vehicle Maintenance Fluids Fluid - A/T Testing and Inspection Component Tests and General Diagnostics Fluid Condition Check
FLUID CONDITION CHECK
1. Perform the fluid level check.
2. Observe the color and odor of the fluid. It should be dark reddish, not brown or black. Odor can sometimes indicate that there is an overheating condition clutch disc failure or band failure.
3. Use an absorbent white facial tissue to wipe the fluid level indicator. Examine the stain for evidence of solids (specks of any kind) and for signs of antifreeze (gum or varnish on the fluid level indicator).
If specks are present in the fluid or there is evidence of antifreeze, the transmission fluid pan must be removed for further inspection. If fluid contamination or transmission failure is confirmed by further evidence of coolant or excessive solids in the transmission fluid pan, the transmission must be disassembled and completely cleaned and serviced. This includes cleaning the torque converter and transmission cooling system. Do not perform any further checks before cleaning and servicing the transmission. During disassembly and assembly, all overhaul checks and adjustments of clearances and end play must be made. After the transmission has been serviced, all diagnostic tests and adjustments listed in the Diagnosis by Symptom chart must be completed to ensure the concern has been corrected.
__________________________________________________________
Let me know what you find.
Oct 6, 2020 at 6:41 AM
JAY-12849
  • 5 POSTS
That’s what I found.
Oct 7, 2020 at 4:02 PM
  • 110,248 POSTS
I can't tell for sure, but it looks like the stick is dry indicating low fluid. Is that correct?
Oct 8, 2020 at 11:15 AM
JAY-12849
  • 5 POSTS
I really don’t know??
Oct 9, 2020 at 6:38 PM
  • 110,248 POSTS
I copied a pic from your video. There should be transmission fluid on the stick where I circled. It should reach to the cross hatches on the stick. If you look at the pic I attached earlier, it will indicate where the level on the stick should be.
Start the engine and allow it to reach operating temp. With the engine running (idle) and in park, remove the dipstick from the transmission and see if there is any fluid on the stick. It will be reddish in color.
If there is nothing on the stick, that is likely the problem. Hopefully it isn't too low.
Oct 10, 2020 at 9:53 AM
