Check engine code po1681
160,000 MILES • 3.5L • 3 CYL • 2WD • AUTOMATIC
FARR2007
  • 244 POSTS
What does code po1681 mean?
Jun 19, 2018 at 10:51 PM
Good morning.
It is a communication issue with the fuel gauge.
Symptom:
P1681-No fuel level BUS message.
When monitored:
Ignition on.
Set condition:
No fuel level BUS messages received by the PCM for 20 seconds.
Possible causes:
- DTC reset
- Communicate with BCM
- Fuel level bus message
- PCI bus circuit open from PCM to BCM
- BCM
Jun 20, 2018 at 9:49 PM
