Check engine code P2122 accelerator pedal position sensor
150,000 MILES • 5.9L • 6 CYL • 4WD • MANUAL
GAITHER TUCKER
  • 10 POSTS
Code said the voltage is low at APP sensor. What pin does the five volts appear on the sensor and where does it originate?
Mar 9, 2018 at 8:31 AM
Good morning.
check the orange wire at the throttle position sensor at the throttle body for 5 volts. check at the pedal sensor for the same.
the voltages originates at the pcm.
P2122
Descriptor
Accelerator Pedal Position Sensor # 1 Low
Low Voltage At The App Sensor
Probable Causes
5 Volt Supply Circuit Open
5 Volt Supply Circuit Shorted to Ground
Accelerator Pedal Position (APP) Sensor
Accelerator Pedal Position Sensor (APPS)
Accelerator Pedal Position Sensor (APPS) 1 Signal Circuit Shorted to Ground or Return
Accelerator Pedal Position Sensor (APPS) 1 Supply Circuit Shorted to Ground or Return
Accelerator Pedal Position Sensor (APPS) No. 1 Signal Circuit Open
Accelerator Pedal Position Sensor (APPS) No. 1 Signal Circuit Shorted to Ground
Accelerator Pedal Position Sensor (APPS) No. 1 Signal Circuit Shorted to Sensor Return Circuit
Accelerator Pedal Position Sensor (APPS) No. 1 Sweep
Engine Control Module (ECM)
Intermittent Condition
Open Accelerator Pedal Position Sensor (APPS) 1 Signal Circuit
Open Accelerator Pedal Position Sensor (APPS) 1 Supply Circuit
Open Circuit On the Ratiometric Wire
Open Circuit On the Supply Wire
Powertrain Control Module (PCM)
Ratiometric Circuit Shorted to Accelerator Pedal Position Sensor (APPS) Return, Battery Negative, or Sensor 1 Return
Ratiometric Circuit Shorted to Hot Idle Switch Circuit
Ratiometric Circuit Shorted to Idle Switch Circuit
Supply Circuit Shorted to Accelerator Pedal Position Sensor (APPS) Return, Battery Negative, or Sensor 1 Return
Wiring Harness or Connectors
Mar 9, 2018 at 9:55 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
App wiring.
Mar 10, 2018 at 12:13 AM
GAITHER TUCKER
  • 10 POSTS
Thanks so much for your help. Found shorted five volt supply and fixed the problem.
Mar 14, 2018 at 6:00 AM
GAITHER TUCKER
  • 10 POSTS
Thanks again.
Mar 14, 2018 at 6:02 AM
You are welcome, good find.
Mar 14, 2018 at 6:07 AM
