Check engine/battery
98,765 MILES • 0.6L • 6 CYL • AUTOMATIC
WENDYCASKEY
The check engine and check battery lights both came on and shortly after the car stopped. I had heard a squealing noise that morning but it was very short term and it never came on unless the A/C was running. I had just been advised to change the fan belts but it was not urgent the engine never overheated. could it just be simple fan belts? The reason I am asking is I just had surgery on my neck and cannot work on the car so I am trying to decide if worth fixing.
Aug 6, 2017 at 1:34 PM
  • 55,766 POSTS
Yes it sounds the belts need replacing. Here is a guide to show you how to get the job done:
https://www.2carpros.com/diagrams/mazda/protege/2001
and
https://www.2carpros.com/articles/replace-serpentine-belt
and
Cheers, Ken
Aug 7, 2017 at 9:50 AM
WENDYCASKEY
Thank you I will check on them this evening. would this also prevent the car from starting? I think yes but my dad says I am wrong.
Aug 7, 2017 at 10:10 AM
  • 55,766 POSTS
Yes, if the alternator locked up it would make a noise and stop the car from starting.
Aug 8, 2017 at 6:46 AM
