Check engine and overheating
152,000 MILES • 2.5L • AUTOMATIC
JORTIZGG
My car had a gas emission leak code which we put new gas cap. Also a catalytic converter code in which we put a cleaner. Check engine went away and came back. it recently overheated about a month after putting new gas cap, etc., it recently started overheating so i refilled the coolant which it seemed to need and it did not overheat for two days, until today. the check engine also flashed on and off. What seems to be the problem?
Oct 22, 2017 at 9:38 AM
  • 31,937 POSTS
You need to first act on the coolant leak, get a coolant pressure test done as this will help locate any external leak. do this first and re post if you require further assistance.
Oct 22, 2017 at 5:16 PM
  • 55,588 POSTS
Here are a couple guides that can help.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Oct 25, 2017 at 7:32 AM
