Check engine after VSS diagnosis
190,000 MILES • 6 CYL • AUTOMATIC
DAVID BUSTAMANTE
  • 5 POSTS
Hi! Quick question! I just replaced my VSS in my car. Before I did so, I had it checked by mechanic and he said that is what it was. Now after replacing and clearing check engine light , check engine light has came back on and diagnose still says VSS. Is there more than one VSS on my car?
Aug 28, 2017 at 6:47 AM
HARRY P
  • 2,292 POSTS
Specifically, what is the code number? Because a code does not necessarily indicate a specific sensor, but indicates a problem somewhere on that circuit. It could be that there is a problem with your connector or somewhere else in the wiring.
Aug 28, 2017 at 8:04 AM
DAVID BUSTAMANTE
  • 5 POSTS
P0725 is the code.
Aug 28, 2017 at 8:14 AM
HARRY P
  • 2,292 POSTS
That code is fort the engine speed sensor circuit, not the vehicle speed sensor. I will pull up more information on it in a bit.
Aug 28, 2017 at 11:08 AM
HARRY P
  • 2,292 POSTS
According to Prodemand, the likely cause is that the distributor is leaking oil onto the ignition coil. Look for evidence of this leak. Replace both the distributor and the ignition coil.
Aug 28, 2017 at 11:21 AM
DAVID BUSTAMANTE
  • 5 POSTS
Sorry for late response but thank you very much. It worked.
Sep 23, 2017 at 10:23 AM
  • 55,748 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Sep 26, 2017 at 4:36 AM
