Check engine codes p0008, p0009, p0017, p0018
70,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
MHMAD
  • 7 POSTS
Problem codes:
p0008 bank 1
p0009 bank 2
p0017 bank 1 + bank 2
p0018 bank 1 + bank 2
Mar 31, 2019 at 10:29 PM
Good morning,
How many miles are on the car?
These codes are usually a result of oil sludge in the variable cam actuators.
The oil system should be flushed of all debris with a pressure machine that gets the inside of the passages clear of the sludge.
This could also be a worn timing chain as well.
I would start there before going to other areas.
P0008: Engine Position System Performance Bank 1
P0009: Engine Position System Performance Bank 2
Related Vehicles: 2009 - 2011 Acadia, Enclave, Outlook, Traverse 3.6L
Notes/Hints:
Poor maintenance or engine mechanical conditions, such as improper engine oil level, condition and type, worn camshaft timing components, low engine oil pressure, or sludge can effect these codes.
Some Techs are reporting new aftermarket timing chains stretched with only 15k miles and tensioners allowing the chain to jump. Always use high quality parts that meet OEM specifications.
A single failed camshaft actuator or solenoid will not set these codes.
Multiple actuator codes in both banks indicate a primary timing chain problem or a slipped crankshaft reluctor wheel.
Preliminary Tasks:
Follow any TSB recommendations.
Repair any other Camshaft Position Actuator Solenoid or Camshaft Position Sensor codes first.
Verify the ECM has the most up-to-date software and calibrations installed.
Diagnosis:
1. If the timing chain components have NOT been replaced, replace the timing chain components. If the timing chain components have been replaced, proceed to the next step.
--> If the code does not reset, the repair is complete.
--> If the code resets proceed to the next step.
2. Recheck the timing alignment marks. If the intermediate chain sprocket timing window is difficult to see use a camera to verify the timing marks. Chain tensioners should not be extended over 3/8".
--> If any problems are found, make the necessary repairs.
--> If NO problems are found, inspect the crankshaft reluctor wheel for slippage.
Mar 31, 2019 at 10:43 PM
MHMAD
  • 7 POSTS
60,000 miles.
Mar 31, 2019 at 10:48 PM
Should not need a timing chain. They are good for about 150,000.
I would get the oil system flushed out.
Mar 31, 2019 at 10:51 PM
MHMAD
  • 7 POSTS
Is there an explanation of how to do this?
Mar 31, 2019 at 10:54 PM
MHMAD
  • 7 POSTS
Did flash and replaced by 5/30 organic oil yesterday . But the trouble came back.
Mar 31, 2019 at 11:01 PM
You need a flush not a change. That is done with special equipment.
Mar 31, 2019 at 11:11 PM
MHMAD
  • 7 POSTS
i did that but the trouble came back.
Apr 1, 2019 at 4:20 PM
You did what?
Apr 1, 2019 at 8:02 PM
MHMAD
  • 7 POSTS
I was at a mechanic, he put a flush in the engine and changed oil after ten minutes.
Apr 1, 2019 at 8:18 PM
That is not a flush as I stated. It is where they drain the oil and put a machine in where the oil filter goes and the drain plug. It forced a heated cleaning agent throughout the motor internal ports to rid the passages of sludge.
There is no additive that can flush out the passages.
Apr 1, 2019 at 8:24 PM
MHMAD
  • 7 POSTS
Okay, thanks.
Apr 1, 2019 at 8:29 PM
You're welcome.
Always glad to help.
Apr 1, 2019 at 8:59 PM
