check eng light comes on off
146,000 MILES • 2.1L • 4 CYL • 2WD • MANUAL
KENEVIE70
when eng light is on it runs like it's not getting any gas. Step on the gas hard and it excellerates slowly, and feels like it missing and bucks every now and then. When I get up in the morning the car doesn't act up until you drive it for a bit. The longer you drive it the worse it gets. had a good tune up about 4 months ago. mechanic said it needed a ring job. the intake side showed a lot of oil residue. changed filter and cleaned every thing up. Car ran good for about 2 month's and slowly got to where it is today. Just recently passed smog. What do you thing?
Jun 12, 2014 at 1:22 PM
  • 31,937 POSTS
With the engine light on there will be a stored fault code in the ECU, you need to go get a scan done and report what codes are set here for further assistance.
Jun 13, 2014 at 8:53 AM
