Check engine light comes on and starts to misfire
NEIL WHITE2
  • 2000 NISSAN FRONTIER
  • 3.3L
  • V6
  • 4WD
  • MANUAL
  • 188,000 MILES
My truck runs all right but after a while the check engine light is on. Then sometimes it misfires, other times runs alright. I have omd2 scanner and don't get any codes on it when the check engine light is on.
Sunday, August 18th, 2019 AT 10:38 PM
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. If the check engine light comes on then there should be codes posted. You may need to try a different scan tool. If you have a P0300 then I would suspect a faulty distributor.
Tuesday, August 20th, 2019 AT 1:01 AM
